I got this error after upgrading the controller and codesys from SP4 to SP5. There is no data stored in the .sqlite files, however they are created.
I have added a bunch of trend recordings to the Project, after that I got this database error. I have tried to replicate the error by starting a new Project and just adding alarm manager with alarmstorage and trend recording but that Project works as intended. I have changed the compiler to the new version and update the device. I have tried to delete Alarm manager and TrendRecording and adding those again, still no luck. Any ideas?
l am looking pc task manager cpu used;%15-40 , used memory:%25-35 , Codesys RT Configuration used memory:%25-35 and Harddisc have got 40gb free..
la have got 28 trends my project but only 9 trend is runing l see that visulation.But if l looking Program Files/Codesys3.5/Codesys RTE3.5 my trends SQLΔ°TE files is increasing..
Can u give me any idea?
l am using Siemens Profinet controller.
Thanks
BR
Recep
Hello,
Hello;
codesyssupport Pls give an answer l have same problem..
Hi,
39437 means:
SQLITE_NOMEM A malloc() failed "
Is it possible that you run out of memory with your device?
Which Controller are you using?
BR
Edwin
Hi Edwin;
Thanks
BR
Recep
Hi,
you could change the default setting (-> allocating 2MB)
by the following setting in the CODESYSControl.cfg
[CmpCAAStorage]Memsys5SizeInMB=x
so you could add 3 as x here to have 3MB Memory allocated for CAA Storage.
BR
Edwin
Hi Edwin;
Thnx for help. I add to *.config your text and its work.Now 28 trends is recording.
Thank you so much
BR
Recep
