I have an application using CNC GCode interpolation, but I need to modify the GCode provided to the PLC based on certain parameters. I am currently attempting to modify the SMC_GeoInfo objects in the SMC_OutQueue using the code below. Note that all the other code is pretty standard and works fine, but when I add the below it errors.
How do I use SMC_GetObj and access the data? It creates a pointer with the value as shown in the photo, but all the dereferenced values say dereference of invalid pointer.
It throws an error when I get to the line
giGeoInfo := pGeoInfo^;Error:
Sometimes you just need to pose a question on a forum and re-read it to get clarity.
This won't work, I'm providing a pointer to a pointer, as poqDataOut is already a pointer! I just need to remove the ADR() and it works.
