Playing with slave in CAM or Geared Axis
zeroptr
2022-11-07
2022-11-14
  • zeroptr - 2022-11-07
    Hi All,
    I have a packing machine project and I have to make a bobbin feed system with a mark sensor. If I make the system CAM or Gear in right conditions it works great for my master and slave axis.
    But when I'm trying to play with axis with MC_Phasing ( I do the recomendation on MC_Phasing help article I use a virtual axis for real CAM).
    AX1 -- 0-360 master exis
    AX2 -- Virtual Master Axis Geared to Axis 1 to 1
    AX3 -- Slave axis
    AX1 GEARED AX2
    AX2 GEARED AX3
    AX1 Phase Shift AX2
    First Problem when I phase AX1 to AX2 gear InSync signal lost but system still works in synch..
    Second problem and the real deal..
    When I shift the angle forward to 50 degrees with double speed of master axis, I expect that AX3 will move forward to 50 degrees, but it makes move reverse..
    I could not solve why this happens.
    Is there any experince to solve this problem or any advice with another way..
    I tried MC_MoveSuperImpose but it crashes the GEARS..
    Thanks..
  • zeroptr - 2022-11-14
    SuperImpose worked after correcting the Acceleration and Deceleration..
