3 axis interpolation
fahansen
2014-10-17
2014-10-31
  • fahansen - 2014-10-17
    I need to interpolate 3-axis with continuous path.
    The application looks like a SCARA robot and all the points are calculated by the PLC.
    The interpolation already works using a G-code with the SMC_NDecoder + SMC_Interopolator + SMC_ControlAxisbyPos, but after each point (G01) the drivers stop and I need to keep running until the last point.
    Its not necessary to use the G-code.
    Any idea how to interpolate without stop?
    thks
    eschwellinger - 2014-10-18
    you need to adjust this with dAngleTol on SMC_CheckVelocities ...
    This input describes the tolerance angle up to which at a sharp bend of the path no stop shall be executed.
  • fahansen - 2014-10-22
    Thanks Edwin!!
    It works when I use a CNC program with fixed coordinate.
    In the program, the PLC calculate all points in a table x, y, z and when use those points to write in variables of g-code (N20 G01 X$p1$ Y$p2$ Z$P3$ F$V1$) still keeping the delay. Believe because the interpolation didnt get the next position before finished the work.
    Is there a way to use a table directly on the SMC_Interpolator or need to use a g-code?
    BR.
    eschwellinger - 2014-10-31
    yes think you need a little more 'look ahead'... so more lines of
    should solve this.
