I am trying to control serad servo via codesys softmotion win v3. But i dont know where to start.
Which softplc i should download and where. is there any manual for codesys softmotion win v3
in general for SoftMotion you need a realtime capable plc - for example:
SoftMotion RTE: http://store.codesys.com/systeme/codesy ... te-sl.html (this is the plc which you install on the target pc - see the documentation what is needed to set to have hard realtime)
Which fieldbus does the 'serad servo' support?
Here are some SoftMotion Projects/tutorial:
c:\Program Files (x86)\3S CODESYS\CODESYS\Projects\SoftMotion\4.1.1.0\Examples\Tutorial\
Which is a good startpoint + onlinehelp.
2017-05-04
Originally created by: eser_
Hi Edwin
Thank you for your help!
Yes i tryed to control servo by softmotion rte. But i have some problems that i cant solve.
Serad servo supports ethercat . But when i add ehtercat in rte control i recieve following errors.
Unresolved reference: 'CLOSEETHERNET'
Unresolved reference: 'GETNUMBEROF ADAPTERS'
Unresolved reference: 'GETADAPTERINFO'
Unresolved reference: 'OPENETHERNET'
Unresolved reference: 'SENDETHFRAME'
Unresolved reference: 'GETETHFRAME'
Unresolved reference: 'SENDIPETHFRAME'
Unresolved reference: 'GETIPETHFRAME'
And as i read from manual i installed ethernet driver form C:\Program Files\3S CODESYS\CODESYS Control RTE3\CmpRTL81x9Mpd. And there i recieve following error.
'This device is not working properly because windows cannot load the drivers required for this driver.'
Also can i control servo by codesys softmotion win v3. And what is the bad side of using codesys softmotion win v3.
please read the RTE documentation...
install in Windows device manager a CODESYS Driver for your network card (Intel or Realtek chipset is needed)
Add this driver to the RTE configuration
Realtek 8139 (CmpRTL81x9Mpd)
Realtek RTL8139 (und kompatiblen) Ethernet-Contoller.
the 8100 und 8110 are compatible too.
2017-05-05
Hi Edwin,
I read rte documentation. And i installed it from deivce manager.
I tryed to install it with another pc but i always recieve this errror(windows error code 31)
Hello
SoftMotion RTE:
Hi Edwin
Realtek 8169 (CmpRTL8169Mpd)
Realtek 8169/810
Realtek RTL8111B / RTL8111D / RTL8111E
Intel EtherExpressPro1000 (CmpEt1000Mpd )
82541,82547,82567,82571,82573,82574,82583V, i210, i217-LM etc
Intel EtherExpress PRO/100 (CmpEt100Drv)
Intel 82551,82557,82559
Intel 82559, 82558, 82557 and 82550
Hi Edwin,
could we get the IDs of your networkinterface?
There is hardware id
hm.. guess you need to contact the Support.
