I wanted to use the Adafruit Hat for the Raspberry and get acquainted with Softmotion using servos for RC models. This did work great with Codesys 3.5.19 Patch 1, but with Patch 4 and 5 i get errors. I suspect changes in the SoftMotion library have broken dependencies in the legacy drivers, might that be true?
In fact, specifying to use SM3_Basic library in version 4.14 fixes the issues, choosing 4.16 raises the same issues.
(Library Manager > Place Holder > Double click on SM3_Basic > Show all versions)
I have the same problem. How can I get the library version 4.14. Is there a download link?
I am working with Codesys for the first time in a long time.
Last edit: tobse 2024-02-24
If I remember well, first you need to delete the current version. Then clicking through the tree as indicated in the previous post, lets you choose the "outdated" libraries.
Thanks for the suggestion, I have tried it eagerly:
I have updated all packages to latest version with Codesys Installer and installed newest runtime and gateway on Raspberry Pi. Unfortunately, the error is still there. As soon as I add the SM_Drive_Servo to the device tree, I get the error below when generating the code. Reverting SM3_Basic to version 4.14 makes the error disappear.
Thanks for any hint,
spiessli
Here the error log:
[FEHLER] sm3_drive_servo, 4.6.0.0 (3s - smart software solutions gmbh): GetStandardConfigParams AXIS_REF_SERVO: C0032: Typ 'Unbekannter Typ: 'ConfigGetParameterValueLREAL(pParam, 0)'' kann nicht in Typ 'LREAL' konvertiert werden
[FEHLER] sm3_drive_servo, 4.6.0.0 (3s - smart software solutions gmbh): GetStandardConfigParams AXIS_REF_SERVO: C0046: Bezeichner 'ConfigGetParameterValueLREAL' nicht definiert
[FEHLER] sm3_drive_servo, 4.6.0.0 (3s - smart software solutions gmbh): GetStandardConfigParams AXIS_REF_SERVO: C0035: Programmname, Funktion oder Funktionsbausteinstanz an Stelle von 'ConfigGetParameterValueLREAL' erwartet
Übersetzung abgeschlossen -- 15 Fehler, 0 Warnungen : Kein Download möglich
use attached projectarchive as workaround.. till this is fixed
what if you use all packages in latest version?
pi Runtime 4.10.0.0 ?
