Anonymous - 2019-09-11
Originally created by: mtanner@gleason.com
I have a v3.5.15 application with a 3S Ethernet/IP scanner communicating with a Hilscher ‘NT 15 RE EIP to Profinet’ adapter. The devices are configured and working correctly.
My problem is knowing if/when the Hilscher device ‘stops running’.
My application works fine. However, I found that if I stop the code at a brake-point the adapter stops updating:
My issue is that I cannot determine programmatically that the adapter is not updating (the eState variable shows Running and the sDiagString does not change):
The CodeSys IDE knows that the adapter is not running:
But neither the adapter or does the Ethernet/IP Scanner device knows the adapter is not running:
If I toggle the xReset variable of the adapter, I can see the eState variable cycle through its states back to Running and the adapter starts updating.
How can I know if the adapter has stopped running so I can reset it?
Thank you.
IMG: Pic_1.png
IMG: Pic_2.png
IMG: Pic_3.png
IMG: Pic_4.png
IMG: Pic_5.png
