profinet coupling between raspberry and beckhoff profinet BK
devlies
2015-10-31
2015-11-01
  • devlies - 2015-10-31
    I have problems communication with profinet IO. Before I go to details should I have to different ethernet ports on the raspberry or not. In some youtube examples i have seen the usage of a usb to ethernet adaptor in combination with wago I/O. What I am trying to do now one ethernetport both for communication between codesys and raspberry Pi and also for profinet communication
    thanks a lot for any advice
    Pieter Devlies
    vives noord belgium
    eschwellinger - 2015-11-01
    both is possible (using the same port or have additional USB adapater)
    If prefer to split it on seperate ports.
    Additional I would recommend to use PI2 for doing profinet.
    You could use this example Project here:
    l viewtopic.php?f=23&t=6247#p12724 l
  • devlies - 2015-11-01
    thanks !
