RasPi as a modbus slave
svantuil
2015-03-25
2017-02-19
  • svantuil - 2015-03-25
    I am currently attempting to connect Ignition SCADA OPC server to the Pi as a modbus tcp slave. I can read the registers beautifully, however when I write to a register, it resets itself after about a second.
    I have tried modbus slave simulators, other devices, and a Wago head unit running CoDeSys 2.3, and they all work correctly.
    I have tried running with a blank program to verify that the POU wasnt doing something silly.
    Is there any settings I am missing in 3.5 SP6 that could be resetting the values?
    Thank you.
    eschwellinger - 2015-03-25
    you need to increase or remove the timeout see screenshot.
    IMG: ModbusSlaveTimeout.jpg
  • svantuil - 2015-03-26
    Days of pulling out my hair, over a checkbox.
    Thats fixed it.
    Thank you for your help Edwin.
  • d.langhojer - 2016-10-16
    Hi.
    I have a wago 8203 as unit for my gate and now i want to use the raspi for the buttons to control it from the house.
    but I gave up because I don't understand how the thing with the registers works.
    Does anyone somehow have a (both) project where the raspi simpli gets 4 outputs from variables out of an working wago project and where the raspi sends 4 inputs to the wago project?
    I just want my hardware buttons be able to be lightet when the gate is not closed.
    AND!: I don't know why this way with 4 inputs and 4 outputs isn't used anyway as remote-buttons over ethernet.....
    eschwellinger - 2016-10-16
    are you using wago 8203 with CODESYS V3 or V2.3?
  • Irden - 2017-02-19
    I have a problem with ModbusTCP_Slave_Device on RPi3 - during program execution there is always message "The bus is not running".
    How can I turn ModbusTCP_Slave on?
    Runtime version 3.5.10
    Version of Ethernet and ModbusTCP_Slave_Device 3.5.10.0 too.
    IMG: scr1.PNG
