Add to EL2521 AXIS ENCODDER FEEDBACK of EL5101
2018-02-05
2018-02-08
  • ibantxispas - 2018-02-05
    Good afternoon,
    To which variable of EL2521 axis I have to put EL5101 encoder value to
    have an axis in close loop mode?
    For the moment only moves in velocity.
    thanks, regards
    Ivan
    eschwellinger - 2018-02-05
    Hi Ivan,
    I would use the available driver for thw EL2521
    But even if you use a Raspberry PI without realtime patch, this drivers might work,
    check with this Settings from the screenshot
    ( & an enbaled DC)
    check this example:
    "c:\Program Files\3S CODESYS\CODESYS\Projects\SoftMotion\4.x.x.0\Examples\Tutorial\PosControl.project"
    IMG: DisableSyncWIndow.jpg
  • ibantxispas - 2018-02-08
    Dear Edwin,
    thanks, it works.
    When is necessary if I use Softmotion with raspberry realtime patch?
    How could I know if my raspberry pi2 is in realtime? I am using EMLID realtime image.
    Raspberry Softmotion is compatible with CNC blocks?
    thanks, regards,
    Ivan
    eschwellinger - 2018-02-08
    check the jitter in the taskmonitor, highes prio task should be <80us I would say for Raspberry PI is good enough...
    IMG: jitter.jpg
