In the morning, Δ± read your answer. I changed udiport value to 4 for using usb-DekTec_Digital_Video_BV device. After that port opened and Δ± sent some data to device. After a few attempts the device again generate error . I thought problem was from device. Changing the device did not solve the problem. The same error still occurs. Codesys can not open serial port.
Best regards
Hi Edwin,
I think I solved problem. I think there is an error in the code that I wrote. When Δ± tried with yours code, serial port opened without any error. If the problem persists I will bother you again.
Thank you so much
Best Regards.
Dear all,
I have read all the topics related to serial communication on the forum. But Δ± cannot open serial port to communicate with my device.
1)I have modified the CODESYSConfig.cfg like this:
[SysEthernet]
Linux.ProtocolFilter=3
[CmpSchedule]
ProcessorLoad.Enable=1
ProcessorLoad.Maximum=95
ProcessorLoad.Interval=5000
[SysCom]
Linux.Devicefile=/dev/serial
2) Add Symbolic Link to /pi folder
#!/bin/sh
# Script to start our application
sudo ln -s /dev/serial/by-id/usb-Prolific_Technology_Inc.USB-Serial_Controller-if00-port0 /dev/serial2
sudo ln -s /dev/serial/by-id/usb-DekTec_Digital_Video_BV_DTM-3237-OEM_DVB-S_DVB-S2_receiver-if00 /dev/serial3
sudo ln -s /dev/serial/by-id/usb-Silicon_Labs_CP2103_USB_to_UART_Bridge_Controller_PDBBRK006518-if00-port0 /dev/serial4
sudo ln -s /dev/serial/by-id/usb-u-blox_AG-_www.u-blox.com_u-blox_GNSS_receiver-if00 /dev/serial5
sudo ln -s /dev/serial/by-id/usb-Silicon_Labs_CP2103_USB_to_UART_Bridge_Controller_0047-if00-port0 /dev/serial6
I can not open serial port with this code. it's generate error. How can i solve this problem?
which value has 'udiPort' in your application?
Should be 3 for using the usb-Prolific_Technology' interface
Hi Edwin,
Thank you for fast response.
Best regards
Hi Edwin,
Thank you so much
Best Regards.
