I used a LAN cable cat 6a from pump (A,B and ground connector) to USB-RS485 converter, connected to raspberry Pi 3:
I want to read/write registers modbus for controlling pump.
In codesys software, I see a error: a red/yellow pulse triangle (in slave_modbus_porta_COM):
and the code don't work. Why ?
Do you have any solution?
to the /etc/CODESYSControl_User.cfg if this is 3.5SP11 version.
(because there is already a section for this)
If done, which channels/function codes to read did you add to your modbus slave?
I have a DAB evoplus small pump
did you modify this USB converter to the plc configuration file?
sudo nano /etc/CODESYSControl_User.cfg
[SysCom]
Linux.Devicefile=/dev/ttyUSB
cheers
plcmax
yes.
this is my Codesys configuration file:
I would recommend to move
[SysCom]
portnum := COM.SysCom.SYS_COMPORT1;
from /etc/CODESYSControl.cfg to /etc/CODESYSControl_User.cfg
This is screenshoot for function:
and this is error in ModbusGeneric SerialSlave (pulse from "bus failure" to "not running"):
You can download Modbus register for DAB Evoplus small pump's from here
ok. Solved !
The Rs485-usb converter was broken.
With new converter is all ok !
