Beckhoff EL72x1 DS402 conversion
MYM
2018-07-09
2021-10-14
  • MYM - 2018-07-09
    How can I convert the EL7211 from mdp72 to ds402?
    When I click the write EEPROM button it asks for a .bin file. So could you please send me this file to complete the update. Cant find it in beckhoff site.
    Best Regards,
  • MYM - 2018-07-11
    I passed that step and converted the module to the DS402 but still cant turn the motor.
    I can not see a page for configuring the motor parameters.
    I read the motor pos from the codesys drive general screen.
    When I run the mc_power command I get a small movement and then warning leds lit and I read the following warnings and error messages from codesys which you can see in the attachments. Could it be because I did not configure the motor parameters? if yes how can I do it? You see the configuration page is empty.
    Best Regards,
    Mete
    IMG: EL7211_3.png
    IMG: el7211.png
    IMG: EL7211_2.png
    eschwellinger - 2018-07-11
    how about your task jitter , guess this will only work with rt_preemt patch on the Raspberry pi..
  • MYM - 2018-07-11
    I will check but I saw in the forum that there is a comment that it would work without the realtime patch.
    Could you please comment about my questions also about the motor parameters configuration and startup parameters section.
    Best Regards,
  • mascara - 2021-10-14
    Did you manage to configure the EL7211?
    Did you find the motor files? I found it only in .xml but I don't know how to install ...
