TrendRecordingTask exception
ranthony63
2018-01-04
2018-01-09
  • ranthony63 - 2018-01-04
    I am using a trend recording widget with BBB. Most of the time it works fine, but sometimes, it crashes after a "Reboot Target".
    The exception error happens in DeterminePreviousConfiguration [TrendFBColumnManager].
    To fix this issue, I need to delete the sqlite databases.
    I have attached a sample project.
    If you run it on a BBB, then restart the target, it sometimes crashes. I noticed it was often linked with a few changes I make on the project, for example, structured code modifications or adding control widgets, then somehow project is not properly updated even with full uploading of the new project.
    Anthony
    IMG: stackTrace.png
    supervision_minimalCrashExemple.project [444.89 KiB]
    eschwellinger - 2018-01-09
    thank you for reporting this,
    I have created a Bug report for this.
    Hope this will be solved in one of the next Versions.
