cmDongle Raspberry Pi issue
fontrap
2024-04-22
2024-04-24
  • fontrap - 2024-04-22
    Hello mates,
    I'm working with CODESYS V3.5 SP20 on a Raspberry Pi and I use "Raspberry Pi MC SL" as device on the project.
    I've installed the Control Standard L (multicore) license
    on a Wibu System usb-Dongle (cmStick/4.50) that already had another license from another vendor.
    I follow the online activation procedure from CODESYS documentation.
    Raspberry Pi has already CodeMeter installed for the other license.
    When I plugin the dongle on Raspberry and start the Runtime from Raspberry Pi Update in CODESYS
    I receive the message that I'm on Demo mode because the license is missing.
    I double checked that the license is activated in the dongle, through the WebAdmin of CodeMeter and the second license
    runs properly without any issue.
    I have already try to change the dongle from HID to MSD device and backward but the the Runtime cannot recognize the Dongle.
    I have also try to stop and start the Runtime through CODESYS without success.
    Is there anything else I can do to fix this issue?
    eschwellinger - 2024-04-22
    which Pi runtime is it? 4.11.0.0?
      Yes 4.11.0.0
    should work for sure as HID device.
    • fontrap - 2024-04-24
      Good morning @eschwellinger,
      After some research I found out that the problem is the preinstalled CodeMeter on Raspberry Pi. As I mentioned the CodeMeter was installed on the Raspberry because I use a license from other vendor that needs the CodeMeter to be installed.
      The problem is that when I uninstall the CodeMeter from Raspberry I am able to detect the dongle from CODESYS and everything works as it should be but now the other product can not detect its own license. When I reinstall the CodeMeter I am back to the initial problem.
      Is there a way to overcome this conflict through CODESYS?
    eschwellinger - 2024-04-24
    use Arm64 SL or Arm SL instead of the PI package - this will work
