how see data of codesys in the java ?
2016-04-22
2016-04-22
  • jader.alvarino - 2016-04-22
    hi , good morning
    i have an program in codesys with some datas , how see will could data from an application java ?, how send data from an java?
    what are the options to solve this problem?
    thanks for your help
  • murdemon - 2016-04-22
    you can use ModbusTCP .. lib on Java.. and configure Codesys programm tomapping nessasery data to modbus
    murdemon hat geschrieben:
    but , codesys and java , they work in the equal PC.
  • Anonymous - 2016-04-22
    That is not a problem. Industrial PCs with touch screen run both CoDeSys and HMI software on the same hardware and communication works as if the HMI is a different piece of hardware. Just set your Modbus client and server to use the same IP address (or even localhost maybe).
