rounding up numbers
NBCC
2017-05-15
2021-04-08
  • NBCC - 2017-05-15
    Hi all,
    Probably a stupid question but i have some troubles with rounding up numbers. So just like 3/2 = 2
    It Always has to be rounded to the biggest number.
    Any suggestions here? (i don't use the oscat library)
    Many thanks.
  • ekmekci - 2017-05-15
    So what do you want ?
    If you want to be see 3/2 = 1.5
    you have to define LREAL variable.
    For example,
    variable1 : LREAL;
    variable1 := 3/2;
    so, you can see variable1 = 1.5
  • Anonymous - 2017-05-15
    There are many ways to always round up, but here is one:
    RVal = REAL(3)/2;
    IVal = INT(3/2);
    If RVal > INT_TO_REAL(IVal) THEN
    Β  Β IVal := IVal + 1;
  • NBCC - 2017-05-15
    scott_cunningham hat geschrieben:
    RVal = REAL(3)/2;
    IVal = INT(3/2);
    Thank you. I tried it and it worked
  • josepmariarams - 2017-10-14
    a/b+((a div b)+(b-1))/b
  • laruso - 2021-04-08
    My proposal for integer values:
        a: INT;   // Dividend
        b: INT;   // Devisor
        c: INT;   // Result
    c := (a-1)/b+1;
    I needed that conversation for getting the correct number of column and row, out of the (overall) count of an array (to correct the code of OSCAT's "CSV_PARSER_FILE_DEMO"). It works with the integrated truncation feature while calculating with integer values. Or you look after "ROUND" functions in OSCAT's library.
