Add a sound to a button
Johan10
2018-04-20
2018-04-22
  • Johan10 - 2018-04-20
    Hello I had a project to drive a car with buttons in Codesys. I’ve finished and now I trying to add a sound to my button « Start»So that when I start, it makes the sound of a car which starts.
    Thank’s a lot
    eschwellinger - 2018-04-21
    which plc are you using?
  • Johan10 - 2018-04-21
    I’m using a Raspberry Pi 3.
    eschwellinger - 2018-04-22
    check this example in the Forum application examples/snippets:
    l viewtopic.php?f=23&t=6247 l
    You could add the sound file as external file in CODESYS (it will be downloaded then by CODESYS to the plc) and then execute it by the command line
    like shown in this example.(This you Need to do in an own Task, because the Task is blocked as Long the sound file is played)
    Keep in mind this solution does play the sound on the PI, not on the _/webvisu where you press the button.
    IMG: executeCommandline.jpg
  • Johan10 - 2018-04-22
    Keeo in mind this solution does play the sound on the PI, not on the _/webvisu where you press the button.
    Thanks a lot
