Not Possible to connect using control SL
winki
2025-01-07
2025-01-10
  • winki - 2025-01-07
    I used to connect into my gateway using control SL tool 4.13, (it was called Update Linux.)
    I formated my computer, so today I install the new version of codesys and all package.
    Now I am not able to connect to my PLC using control SL.
    It says, check the status.
    Normally it used to worked perfectly before that.
    eschwellinger - 2025-01-07
    should work,
    could you please check on the target:
    top
    if the the gateway is running -> you should see codesysedge.bin
    and
    cat /var/opt/codesysedge/codesysedge.log
  • winki - 2025-01-10
    Thx for your help,
    I just Uninstall and install again codesys.
    I did it as admnistrator and now it is working...
    I did not change anything into the target configuration.
    Only my codesys on my computer.
    Loic,
    Thx for your help,
    Loic,
