Using USB to read Data from Sensor on Pi
mageme02
2014-10-20
2015-06-14
  • mageme02 - 2014-10-20
    is it possible to read the data from an external USB Sensor on CODESYS?
    Like: sudo socat /dev/ttyUSB1,b9600 STDOUT
    The command line will prdouce the following.
    $1;1;;;- 0,9;;;17,6;;;;;75;;;59;;;;;;;;;0
    I want to read these Data directly in CODESYS from a weather station (USB from ELV) to control further devices an show the Data in a webViusu.
    Thanks for your help
    Matthias
    eschwellinger - 2014-10-22
    Hi Matthias,
    please try my attached project.
    I've connected a usb to serial adapter, send via a windows terminal programm 'READ_USB' then
    you execute the bREAD which get the data from char device.
    This should work for your device too.
    IMG: CharDevice.jpg
    RaspberryPI_CharDeviceSnippet.project [149.71 KiB]
  • mageme02 - 2014-10-29
    i used your solution in this topic:
    l viewtopic.php?f=21&t=5699&hilit=serial l
    This works well for me
    Thanks for your support!
    eschwellinger - 2014-10-29
    yes sure for serial communication this works,
    in case you have any other char device under Linux - the example might be the choice.
  • zerep - 2015-06-13
    Hi Edwin,
    Could you help me, please? I'm newbie in RaspBerry and in Codesys too, so trying to reading RS232 by RS232 to USB adapter when I open your example in CoDeSys V3.5 SP6 Patch3 I get the following errors:
    Identifier 'CMPCHARDEVICE.RTS_IEC_HANDLE' not defined
    identifer 'CmpCharDevice' not defined
    My RaspBerry is PI 2 Model B
    Max
    eschwellinger - 2015-06-13
    whenever you open an older project the procedure is the following:
    1. Rightclick on the plc device in the device tree -> update device
    In the projectsettings:
    2.- use current Compiler Version
    3.- use current visuprofile
    this should solve these Problems (usually an older library is missing because in the old plc device the placeholder points to a not installed library version)
    This should solve it.
  • zerep - 2015-06-14
    many many thanks, works perfectly?
    BS
    Max
