could you please login by ssh,update manually
by executing: (the debian file should be already copied there to /home/pi) sudo dpkg -i codesyscontrol_arm_raspberry_V3.5.11.0.deb
or (depending on which Version you try to install) sudo dpkg -i codesyscontrol_arm_raspberry_V3.5.11.10.deb
galexis hat geschrieben:
When I put package 3.5.1.0 on home, after reboot, it disappear. When I erase file , after reboot, it reappear ....
It is problem sd card ?
This is just a guess but the big SD cards had an mechanical switch at the side to make the card read-only. I'm not sure if the micro SD cards still have one but that could be the reason why the new files disappear and deleted files re-appear.
Martin
I use CODESYS 3.5 SP11 and raspberry pi.
When I update firmwar to 3.5.11 I have error and after rebbot, new firmwar desappear and old one come back.
Error is :
"Error output: codesyscontrol.bin: aucun processus trouvé insserv: script codesyscontrol is not an executable regular file, skipped ! tar: Suppression de "/" au début des noms des membres update-rc.d: warning : default stop run levelarguments (0 1 6) do not match codesyscontrol Default-Stop Values (none)"
How can I resolve it ?
Thanks for your helps.
I have a similar problem:
hi,
which debian version is this...
guess this is not a CODESYS related problem do you agree?
Hi galexis.
Martin
Raspbian is 4.11.19.
I think sd card is dead. I have order a new one.
