telegram with codesys
suibaf
2016-01-11
2016-01-13
  • suibaf - 2016-01-11
    as you can see at http://www.instructables.com/id/Raspber ... -Telegram/
    it is possible to request information or execute action with telegram installed on raspberry via lua script.
    Is it possible to do the same using codesys instead lua script?
    Thank you.
    Is it my question with no sense?
    eschwellinger - 2016-01-13
    no question is clear.
    I would recommend to use Sys_Execute_Process2 check the following example:
    l viewtopic.php?f=23&t=6247#p12711 l
  • suibaf - 2016-01-13
    Thank you very much!!! you are very kind
