How to configure OPC-UA server
2018-11-23
2018-11-26
  • garmenmikel - 2018-11-23
    Hello!
    I want to know if there is any way to configure some parameters on the OPC-UA server. I need to configure the security of the server. First of all, I created the certificates of the server and I set up an encrypted connection with UaExpert following the steps of the page:
    https://help.codesys.com/webapp/_cds_ru ... n=3.5.13.0
    But, when I insert the server endpoint in UaExpert, I see that I can communicate with the server using three types of Security Settings:
    None - None
    Basic256Sha256 - Sign
    Basic256Sha256 - Sign & Encrypt
    I got to communicate perfecty with certificates, but I want to appear only Basic256Sha256 - Sign&Encrypt there, because I have seen that I can communicate perfectly with the server using the None - None configuration without having to use any type of certificate (and this I don't like it).
    Where can I configure this settings? Is there any configuration file in the Codesys program or is it any in the Raspberry?
    Thanks!!
    eschwellinger - 2018-11-25
    need to check, but I guess this will work with 3.5SP14 -release ( December)
    eschwellinger - 2018-11-26
    approved!
    With 3.5SP14 Release this will be possible to set.
