BeagleBone Black Selfmade CAN Cape
Hummek1904
2016-12-13
2019-07-04
  • Hummek1904 - 2016-12-13
    Hello together,
    I try to connect a Beaglebone Black with CANBus. So i build a Beaglebone Cape for CANBus (you see it in picture):
    After that, i followed the instruction of this link: http://www.thomas-wedemeyer.de/beaglebo ... ython.html until the CAN test part (because it doesnt work for me).
    And now the Problem: If i try to test the bus with "./cansend can0" nothing happens. So i have measure P9 Pin24 (UART1 TXD) againgst ground and the level still stay at 3,1 V (P.S. i measure with a PicoScope).
    Now the question is: what did i do wrong ? Or can there be an other mistake ?
    Thanks in advance.
    Regards
    Hummek
    IMG: DIY Schematic.jpg
    eschwellinger - 2016-12-13
    using other can capes you need to enable them by:
    'For using a CAN cape add following line to /boot/uEnv.txt:
    cape_enable=bone_capemgr.enable_partno=BB-CAN1'
    Maybe this helps or at least you know what to 'google' for.
  • Anerdgy - 2019-07-04
    Just if others find their way here.
    I used the same link https://www.thomas-wedemeyer.de/beaglebone-canbus-python.html
    Followed it all the way through for auto start etc and it works fine.
    for candump you may need to install can-utils ........ ```
    sudo apt-get install can-utils
    then cd /usr/bin
    then you can just run ```
    candump can1
    ``` NOTE it is can1 NOT can0 !!!!
    In codesys make sure to set the Canbus Network to 1 (Not 0) and the correct baudrate
    Then add Canopen Manager and then a device.
    And if the device is sending PDO's you'll be able to monitor this immediately.
    Hope this helps
