Hello, struggling with finding a way to change the target's IP address from within the PLC runtime. This is a feature that has always been available from WAGO on CoDeSys 2.3 and e!Cockpit Is there a TCP/IP config library or Linux command line block that will accomplish this?
for me it works with adding the setting (add the Interface which you want to set)
[SysSocket]
Adapter.0.Name="ethX2"
Adapter.0.EnableSetIpAndMask=1
in /etc/CODESYSControl.cfg
and set the IP by adding the 'Ethernet Connector' to your project and set 'Change Operation System setting' see screenshot
CheckLicensePFC200.project [79.32 KiB] (forum.codesys.com)
