I have a plc Eaton XC303 with 8 HMI connected. If I want to connect just on more I can't. I have disconnect all the hmi. Under device page, shell plc, I send "channelinfo" command and the respose is:
It is obvious that the plc can handle a maximum of 8 channels. It's a plc's limit? It's a codesys' limit? How can I find a workaround?
Thank you and sorry for my english.
CmpChannelServer channel information:
Maximum 8 channels (at timestamp 109477)
Channel 0: OPEN PROCESSING AddrPeer 30CA.C0A8.896F.800F, ChannelId 50168, ComBufferSize 95776, LastRxTime 109476, LastTxTime 109466
Channel 1: FREE
Channel 2: FREE
Channel 3: FREE
Channel 4: FREE
Channel 5: FREE
Channel 6: FREE
Channel 7: FREE
Can you access the .cfg-file? If so add or change this entry:
Maybe the file is in a similar position as CODESYS Control for Linux SL.
https://faq.codesys.com/display/CDSFAQ/Location+of+the+configuration+file
It works! Thank you very much!
