Which networkcards are supported for ethercat and Profinet
2015-02-21
2016-02-10
    eschwellinger - 2015-02-21
    Realtek 8139 (CmpRTL81x9Mpd)
    Realtek RTL8139 (and compatible nic's) Ethernet-Contoller.
    the 8100 und 8110 are compatible too.
    Realtek 8169 (CmpRTL8169Mpd)
    Realtek 8169/810
    Realtek RTL8111B / RTL8111D
    Intel EtherExpressPro1000 (CmpEt1000Drv )
    Intel 82541,82547,82567,82571,82573,82574,82583V, i210, i217-LM
    Intel EtherExpress PRO/100 (CmpEt100Drv)
    Intel 82551,82557,82559, 82558, 82557 and 82550
    This drivers are needed for using the ethercat master, profinet Controller and Ethernet ip scanner and Ethernet IP Adapter
    on Control RTE.
  • Giulix72 - 2015-07-20
    Does RTL8111E controller supported ?
    I'm interest to use Ethercat master on a panel PC that mount this controller. Is "E" char in controller name outstanding ?
    PanelPC is: http://www.ieiworld.com/product_groups/ ... azYyLVBnng m
    eschwellinger - 2015-08-13
    yes should work, if not please let us know.
  • lsislsis - 2016-02-09
    I use the "Codesys Control Win V3" in the same PC with development and all running OK for:
    * profinet on VMWARE Intel Pro/1000 nic.
    When i try to run the same project in an Advantech PC with "Codesys Control Win V3" the Ethernet bus not work if i use the profinet.
    * profinet on Realtek PCIe GBE Family Controller.
    With profinet the Ethernet bus not work.
    Without profinet the Ethernet bus work.
    I try to run in the Advantech PC with "Codesys Control RTE V3" but then i have hardware compatibility problems.
    Please help because i am in midle of project and ihave spend much of my time for tests.
    Regards
    IMG: WinPLC_adapter.png
    IMG: WinPLC_fault.png
    IMG: WinPLC_fault_02.png
    IMG: WinPLC_ok_01.png
    IMG: WinPLC_ok_02.png
    eschwellinger - 2016-02-10
    for Profinet you need to install a CODESYS network driver. (same which you need to ethercat)
    not sure if it does fit (you might check the hardware id's in windows device manager)
    I would give CmpRTL8169Mpd a try
  • lsislsis - 2016-02-10
    Hi Edwin
    Please give me instructions where to find the driver and how to use for:
    Codesys Control RTE and Codesys Control Win PLC.
    Regards
    Control RTE:
    see the Control RTE user manual for the instructions on how to install the Windows driver...
    -> Windows DeviceManager networkdriver you need to replace the existing Realtek to the CODESYS Realtek Driver then add it to CODESYSControl.cfg
    and after doing this a reboot is needed.
    Control Win:
    You need to install WPcap for using every networkdriver (manufacturer independent)
    Hi Edwin
    I try your instructions and work OK for Control WIN with default driver or with Codesys CmpRTL8169Mpd driver but with Control RTE works for a litle and after 1 to 10 seconds i take error exception:
    Any help?
    Another one tell me how to work the Serial Comms with Control RTE.
    Regards
    IMG: Profinet_freeze.png
    yes this is a known bug which will be solved with 3.5SP8Patch1 (release is 18th February)
    If you need a.s.a.p a bugfix I could give a release Candidate for Patch1.... write to 3S Support.
    For serial communication I could send an Project example if needed.
    Hi Edwin
    Please do something quick because i need tomorrow start the project tests at my costumer place.
    Until now i have do my tests with Raspberry run time but for the final project i need to work with Control RTE.
    Regards
    I've sent you an email...
    Hi Edwin
    The update of patch stops after a while because try to find the "disk:1".
    Any suggestion
    Regards
