Can't update to 3.5.9.20
Gianni
2016-10-08
2016-10-16
  • Gianni - 2016-10-08
    I Can't update the Raspberry Pi 2 to versione 3.5.9.20.
    When I try to update the system tell me thats work, but still remain the old version 3.5.8.10.
    I have tried to update it manually but doesn't work too.
    Gianni
    eschwellinger - 2016-10-09
    you could execute by ssh or in the local console:
    sudo dpkg --purge -r codesyscontrol
    Then try to install the new one.
  • Gianni - 2016-10-15
    It doesn't work.
    When I install the new version manually this message will appare:
    Zitat:
    Unpacking replacement codesyscontrol ...
    make_daemonrc
    update-rc.d: using dependency based boot sequencing
    insserv: script codesyscontrol is not an executable regular file, skipped!
    Setting up codesyscontrol (3.5.9.20) ...
    make_touch
    make_blacklist
    make etc modules
    make_daemon
    Backup licenses
    tar: Removing leading `/' from member names
    pid 12899's current affinity mask: f
    pid 12899's new affinity mask: 1
    codesyscontrol started
    update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match codesyscontrol Default-Stop values (none)
    postinst finished
    Wen I try to download the project the message is:
    Zitat:
    The device version '3.5.8.10' ...
    Gianni
    eschwellinger - 2016-10-16
    Is not an regular file.... this seems to be the problem.
    Is this really jessi in current version.
    Br
