IΒ΄m new to Codesys and I'm having trouble to work with CODESYS Control Win V3, it does not start. When I try to open it, an error message appears as bellow:
"One of the following licenses is required:
CodeMeter 101597:13
Failure reason: CmContainer Entry not found, Error 200.
CodeMeterAct 5000304:13
Failure reason: CmContainer Entry not found, Error 200."
I want to use the demo license, so I think it's not necessary to proceed with an activation right? Already done some Google research but find nothing that helps, so I would appreciate a lot if you could help with this.
you need to install:
"c:\Program Files\CODESYS 3.5.16.20\Temp\Patch_ProtectionUpdateFile.WibuCmRaU"
either by double click on it or drag an drop into the codemeter window
Hello everybody,
CodeMeter 101597:13
Thanks in advance.
Fabio.
Last edit: eschwellinger 2020-10-26
