Raspberry Download error "Download denied on Application from CmpDevice"
2016-05-21
2016-05-23
  • Anonymous - 2016-05-21
    Originally created by: Francesco Saverio
    I am a new user and I got a typical strange" error.
    I moved the Rpy from one LAN to another.
    The Rpy is seen from Codesys but after compiling the following message appears:
    Details:
    CmpName=CmpApp,
    CmpId=ox0000002,
    ClassID=ox00010004,
    ErrorID=0x00000001,
    InfoID=0x0000000032,
    The devise has a Raspberry Code Licence
    What was wrong?
    Mybe someone can help me!
    Francesco
    eschwellinger - 2016-05-22
    could you give us the following Output (Login by ssh - puty)
    cat /tmp/codesyscontrol.log
  • Anonymous - 2016-05-22
    I realised that codesys is unable to delete the applications running into the Rpy :
    HiddenOnlineConfigModeApp
    Application
    Is there a way to force it?
    Fsl
    codesyscontrol.zip [123.33 KiB]
    you could delete this:
    either by ResetOriginDevice or remove the Application in the Application Dialog.
    IMG: Remove.jpg
    IMG: ResetOriginDevice.jpg
  • Anonymous - 2016-05-23
    Hi Edwin,
    nok: it is impossible to delete, stop, upgrade the applications.
    Is it possible to deinstall from Rpy without formatting the SD card?
    Fsl
    eschwellinger - 2016-05-23
    then Login by ssh (putty)
    and remove the Application by execute the following:
    sudo -s
    rm /root/app*
