i try to use the Netvars from Oscat Netlib to communicate between
a wago 750-889 Codesys V2.3 and a Raspberry Pi Codesys 3.5.12
My Masterside is the 889, running and telling me a timeout failure
My Clientside is the Raspberry, telling me a Failure 02 what means that
the ip_control block has a failure with running "SysSockBind"
anybody know how to solve this?
i am using the netlib from the codesys store,
or is there a special "raspberry" netlib from oscat for this?
best regards,
markus
I would recommend to post this question in the OSCAT Forum,
sure the CODESYS netvars are even not simple to configure ( to have communication between CODESYS V2.3 and V3)
but even this could be a solution for your application
best regards,
markus
Thanks for your replay edwin,
i found the solution for me.
If i turn on UDP everything is working...
best regards
