Hello, sorry for my bad english, come from germany.
What do I want to do:
I have a sms center running at Rasppery.
If now a sms received,
I turn on a gpio port.
This gpio port I ask in codeys.
Then I solve an action, for example: start a video, switch an output, etc.
Is it not possible that I in my rasppery script directly a variable in codesys switch?
Just as it is also possible to send from codesys commands to rasperry!
Here is the script with which I evaluated an incoming sms:
#!/bin/bash
PASSWORD="1234"
if [ "$1" = "RECEIVED" ]; then
TEXT=sed -e '1,/^$/ d' < $2
# Make text uppercase:
TEXT=echo "$TEXT" | tr "a-z" "A-Z"
Is it possible to send commands from the pi to codesys?
for example:
Turn on or off a marker?
With the PI Terminal.
Thanks in advance
you mean if the CODESYS development system is connected there should popup a dialog in CODESYS with an advice?
#!/bin/bash
PASSWORD="1234"
TEXT=
sed -e '1,/^$/ d' < $2# Make text uppercase:
TEXT=
echo "$TEXT" | tr "a-z" "A-Z"RCVPASS=
echo "$TEXT" | cut -d" " -f1ACTION=
echo "$TEXT" | cut -d" " -f2if [ "$PASSWORD" = "$RCVPASS" ]; then
fi
fi
I hope you can understand my english
maybe it work to use: l viewtopic.php?f=23&t=6247&p=12699#p12711 l
and parse the return values of your script in CODESYS not 100% sure if this will work.
