TargetVisu on Raspberry?
brotjob
2015-02-25
2024-08-28
  • brotjob - 2015-02-25
    I would like to show a visualization on the screen of my PI. Is that possible? How?
    I tried the multitouch example in the store and converted it to a raspberry. It does not give an error message but nothing is shown on a screen connected to the Raspberry neither.
    I see many different communication ways like SPI, GPIO, Ethernet but I do not see the HDMI interface in the tree of available devices...
    Pleasde tell me that it is possible!
    eschwellinger - 2015-02-26
    Target Visu is not supported you could use
    Chromium in kioks mode, this is then like fullscreen targetvisu:
    How to archive this?
    You need to install the following:
    1. Install chromium, x11-xserver-utils and uncluttersudo apt-get update && apt-get upgrade -y
    sudo apt-get install chromium x11-xserver-utils unclutter
    2. We need to prevent screen from going blank and disable screen saver.
    – edit /etc/xdg/lxsession/LXDE/autostart and comment # screen saver line and add those lines:
    sind buster (
    sudo nano /etc/xdg/lxsession/LXDE-pi/autostart )
    @xset s off
    @xset -dpms
    @xset s noblank
    @chromium --kiosk --incognito http://localhost:8080/webvisu.htm
    another option would be to use a Pi2 and use the Empipany Browser which is installed on Raspian Wheezy.
    Pi 2 is needed because on the old Pi's (all others except Pi 2 ) this browser does not work with the plc webvisu.
    Last edit: eschwellinger 2020-04-30
  • brotjob - 2015-02-26
    Dear Edwin
    Thanks for the quick reply. I will try the browser. But I am disappointed because the possibilities are limited in Epihany especially when it comes to multitouch. Is there a plan to support TargetVisu?
    not sure because I have no touch connected to the pi,
    but with 3.5SP6 multi touch should be supported in Webvisu.
    So if you have really a multitouch enabled/supported touchscreen (from hardware side) this should
    work.
    Which device (LCD/Touch) do you plan to use? Not sure if there are many out there (which really have hw multitouch support) and available for the Pi,
    maybe I'm wrong.
    There are no plans to support Targetvisu for the Raspberry Pi at the moment.
    You should get one!
    Really? I use Iceweasel now and I can display the demos. But they behave just like a website. What does not work is to _ with gestures or to switch tabs with swiping. No difference between a codesys website and other websites here.
    Which device (LCD/Touch) do you plan to use? Not sure if there are many out there (which really have hw multitouch support) and available for the Pi, maybe I'm wrong.
    I use the Beetronics 10" touch. I plan to use a 14" from Chalk-Elec too. AFAIK you don't need a special Raspberry touch. Any HDMI touch should work. At least I didn't install any drivers.
    eschwellinger - 2015-02-27
    have you activated moultitouch handling?
    IMG: Multitouch.jpg
  • brotjob - 2015-02-27
    I got the multitouch example to run on Raspberry using Iceweasel or Epihany. Kweb did not work because it does not support HTML5 canvas.
    In this example, multitouch is of course enabled by default However, the only multitouch effect that works is to adjust one slider. _, flicking, adjusting multiple sliders does not work.
  • johnlee - 2015-03-19
    Hi Edwin,
    I have configure the raspberry pi2 as follow your step to get chromium to autostart and point to webvisu.
    But nothing happen when PI2 restart.
    Please kindly advice.
    PI2 is using Raspbian Debian Wheezy from Raspberry PI and Codesys are install via the deb file.
    Thank you
    John.
    I have figure out on the PI2 there is 2 LXDE folder, 1:LXDE ;2:LXDE-pi. it shall change the autostart in the LXDE-pi folder.
    now my pi2 is working with Chromium autostart and point to local webvisu.
  • brotjob - 2015-03-24
    attached a video, which should show that multi touch is possible with 3.5SP6 on webvisu.
    chalk-elec FAQ
    What did you do to enable multitouch? Or did you use another device (not raspberry based) on the youtube video?
    With device I did not mean the "device" in Codesys development system but the hardware device (screen with multitouch). I do not see in the video if the screen is connected to a raspbery (by HDMI and USB).
    eschwellinger - 2015-03-24
    I do not have a hardware device which is connected by HDMI which does support multitouch sorry for that.
    The only thing what I could prove is:
    Webvisu could handle multitouch Inputs / gestures
    I have a Pi loaded with these attached project - I have connected the Pi with Andoid or IPad and I use then the browser of the IPad or Android
    for the Webvisu with multitouch.
    Now we need to figure out why this does not work with chromium or which browser do you use for the test with the local webvisu on the pi at the moment?
  • brotjob - 2015-03-25
    I tried many browsers but chromium seems to be a good choice since it supports command line parameters and it seems faster than iceweasel. Epihany is fast but offers no kiosk mode.
    It may be possible this is no Codesys issue but Linux related. I am new to operating Linux with touch. I will try more command line options soon, I've seen there is a --touch-enable and --enable-viewport option.
    When I try the option --enable-viewport I get a really bizarre picture so this doesn't work.
    When I try the option --touch-enable Chromium starts but I get many error messages. The first one of them was "Failed to load NSS libraries." which I could remove with "sudo ln -s /usr/lib/arm-linux-gnueabihf/nss/ /usr/lib/nss"
    The other errors are "ERROR: browser_main_loop.cc [] GLib-GObject: Attempt to load property GtkSettings...
    libgtk2.0-0 and libgtk 2.0-bin are installed. Installing the sources libgtk2.0-dev did not help.
    Also the Codesys example does not work in Epihany or Iceweasel even if I try "echo W X Y Z > /sys/module/hid_multitouch/drivers/hid\:hid-multitouch/new_id" in /etc/rc.conf
    Any ideas? I think multitouch is essential for a modern embedded system.
    I just managed to get my very first gesture to work on raspberrypi: I used Iceweasel with Grab and Drag 3.2.5.2 extension. I am able to scroll a normal web page now using flicks. No multitouch with Codesys yet...
    Debian is not known for his multitouch support as oppoed to android.
  • Anonymous - 2016-03-17
    Originally created by: andreas.sauerwein2
    I just setup a target visu on my raspberry the way you described it here. But I got a small problem.
    F.E. I have a visualisation with the size of "1920x1200" set to automatic screen size.
    The Webvisualisation elelement is set to "Anisotropic".
    Screen size is "800x480".
    I run "chromium-browser --kiosk http://127.0.0.1:8080/webvisu.htm". The Visualisation is loaded, but it does not use the full screen size ( see picture). But when I hit refresh the whole screen is used.
    IMG: IMG_20160317_105008.jpg
    IMG: IMG_20160317_105015.jpg
  • Tyro - 2020-09-26
    try
    chromium-browser --full-screen http://127.0.0.1:8080/webvisu.htm
  • Thillai - 2021-08-31
    Is there any update on support for Target Visu with Raspberry Pi4?.
    eschwellinger - 2021-08-31
    no - there are no plans for that - most users seem to be happy with local webvisu in chromium browser as fullscreen.
    (As me)
  • Thillai - 2021-09-01
    I have seen Remote Target Visu on the visualization manager to add. Is it same as Web visu?.How can I use it?
    eschwellinger - 2021-09-01
    it is not the same:
    If you execute this:
    c:\Program Files\CODESYS 3.5.17.10\GatewayPLC\RemoteTargetVisu.exe
    on your CODESYS PC - then you could connect to any CODESYS plc and show the visualisation.
    Just give it a try.
  • sukrit - 2024-07-25
    Hello all,
    I have seen someone using targetvisu on linux based embeded system with touch screen. can you guide in this direction how to run targetvisu.
    regards
    Harmeet
    eschwellinger - 2024-07-26
    install this:
    https://store.codesys.com/de/codesys-targetvisu-for-linux.html
    via CODESYS Installer and deploy it by update command
    • sukrit - 2024-08-28
      thanks for this, w need to know the requirements on linux side... can you guide towards a linux installation package..
