Hi there,
I developed a CODESYS 3-IO driver for the Monarco Hat by Monarco.io. A SPI based Hat device for the raspberry Pi. The .package file is too big, so I decided to post a link to my git where you can find it.
Implemented as CODESYS 3 IO device-driver; Open source, Pure IEC code (ST). No function block calls in your software necessary, just write code, attach variable to an I/O channel, ready! Breaks compatibility with earlier FB version but improves highly on ease of use, 4 Di, 4 Do, 2 Ai, 2 Ao, Hardware Watchdog, Control Byte (experimental). Stable, but work in progress ...
Also, other CODESYS 3 goodies can be found there, leave a comment
https://github.com/Aliazzzz/
With kind regards,
Aliazzz
Codesys Application Composer "FirstSteps" Example implemented with the Monarco V2.0.0.0 Library;
https://github.com/Aliazzzz/Monarco-HAT-library-for-CODESYS-V3/tree/master/Monarco/FirstSteps
Hi there,
With kind regards,
Aliazzz
