we just add all needed components to the runtime (obviously without this script)
As you need anyway to build a customized kernel with included socketcan (or is this nowadays not needed anymore?)
At that time we decide just add the license for the users which manage to deal with restricitions.
I have a problem with the rts_set_baud.sh script.
I donβt understand, the script is at root
Have you an solution ?
thks
David
I would recommend to check how this is done in beaglebone black
there the can is supported.
Ok thanks for your advice.
But the canbus is no longer supported on the RPI?
I think i don't need a specfic kernel.
My application requires just CANBUS with sofmotion light for 3 axis.
My can RPI canboard is avaible but codesys script is disable.
I have find a solution to done the canBus.
I use a RaspiLC Iso:
Raspbian Jessie-Desktop Kernel 4.9 Codesys-Runtime 3.5.11
But now i have this: Module not found
