recipe in a pendrive
jbarrio
2018-11-28
2018-12-11
  • jbarrio - 2018-11-28
    Hello:
    I am doing a program that to have persistent variables I am using the formula manager. That is achieved and it works well.
    Now what I want to know if there is the possibility of saving the file in the plc in the place where I want instead of in the path / var / opt / codesys / Plclogic, since I would like to try to save in a plc, and put the computer in read-only mode to try to avoid corrupting the sd if there is a voltage failure.
    I'm using the recipemancommands library
    to save RecipeManCommands.ReadAndSaveRecipe
    to reset RecipeManCommands.LoadAndWriteRecipe
    Thanks for your help.
    eschwellinger - 2018-12-05
    you need to change the /etc/CODESYSControl.cfg
    [SysFile]
    FilePath.1=/etc/, 3S.dat
    FilePath.2=/media/sd/, *.txtrecipe
    PlaceholderFilePath.1=/media/sd, $SDCard$
  • jbarrio - 2018-12-11
    hello and thanks:
    Is it possible to save the license file and the program on a pendrive?
    My intention is to leave the sd in read only and in case of corruption the pendrive will not damage the sd,
    Is this possible?
