I would say because your timer is counting in the background and you may be hitting the fb at a .ET value of 35.012s or 34.985s which both doesn't equal 35s. Or are you saying that it is never assigning any value? Is the ST in a function block or in another program?
Good morning,
do you think this code does not produce a result in the vaiabile TapCucStat?
This code is in ST and the TOF is in LD
I see the ET value of the TOF incremented but not assigned to the variable.
Where am I wrong?
Thank you, Alberto
May be possible that you aren t calling from anywhere tour st code?
