IO mapping For ARM device
2021-02-01
2021-02-03
  • krishemanth - 2021-02-01
    Hi All,
    I am new to Codesys, I am working on IO mapping. i have a device description provided without the IO driver. i decided to create a new devdesc and LIB to map them. I took RPI as reference and created driver and LIB. iam able to add the new Driver to the main devdesc. after logging into to my board and start the application. i can see the driver and bus running, also true/ False change in IO mapping tab , however the voltages on the board pins are unchanged. i guess, iam missing a part where we make actual connections to IDE and Physical IO's on board.
    i have attached The devdesc and lib file i created. any help on this topic will help me .
    Thanks,
    -Kris.
  • hermsen
    hermsen - 2021-02-03
    There is quite some extensive documentation about I/O drivers here on Forge, see:
    https://forge.codesys.com/drv/io-drivers/doc/
    • krishemanth - 2021-02-03
      Hermsen,
      Thanks for your reply.
      i already followed this page and modified my IO.devdesv and LIB file. however the voltages on the board pins are unchanged. i should have to copy any other file along with codesyscontrol on to my board?.
      Thanks,
      -Kris.
