Do I need a Single Licence from CodeSYS for CANopen example on Janz emCONTROL?
Kalyani-K
2019-07-05
2019-07-18
  • Kalyani-K - 2019-07-05
    Hello everybody,
    I am testing CANopen on CodeSYS.
    The Device under use is Janz emCONTROL Dynamic 64bit
    The CAN bus is fully functional, up and running.
    However, neither the CANopen_Manager-CANopenRemoteDevice nor the CANopenLocalDevice are running.
    Their status is always "Not running".
    I did check for the licenses on my Janztec. Turns out there is CANopen licence is available only for CANopen Master.
    Is the CANopen Slave not running because of the missing licence?
    Any idea how I should go about it? Has anyone had a similar situation? What did you do about it?
    Any and every input is highly valuable.
    eschwellinger - 2019-07-09
    you could check with this version:
    https://store.codesys.com/device-reader.html
    if the licenses are available.
    With upcoming 3.5SP15 Version it will be possible to check without these application from CODESYS store.
    IMG: DeviceReader.png
    IMG: SP15DeviceReader.png
  • Kalyani-K - 2019-07-18
    I did download and checked for the existing licenses.
    Looks like I don't need any licence for my Janztec controller.
    Thank you very much for your time!
