Hello Edwin,
I am trying to use the project from this forum "http://forum.codesys.com/download/file.php?id=604"(SerialComWithVisuRaspi.projectarchive). After updating all necessary components There is still an error in ComOpen function parameter "usiListLength:= SIZEOF(aParameter) / SIZEOF(COM.PARAMETER)". Can not convert type UINT to type USINT. Where is a problem?
Peter
Hi Edwin,
I downloaded suggested version, but the error still persist. There is a mismatch between types UINT AND USINT. See ComOpen function parameter "usiListLength:= SIZEOF(aParameter) / SIZEOF(COM.PARAMETER)". Can not convert type UINT to type USINT.
i open the project linked in your last post with attachement (SerialComWithVisu.project),
wehn i open it i become lot of errors: Library SM3 is not available.
I use the last version of Codesys 3.5 and Raspi Package 3.5.8.10 .
Can you Help me?
Serghei
But, as You know, CDS are not able to understand this format. Or serial, or TCP.
To solve this problem, I tried to use the socat program http://www.dest-unreach.org/socat/ team socat PTY,link=/dev/ttyCOM tcp:192.168.3.55:502, which creates the most symbolic file /dev/ttyCOM, (lrwxrwxrwx 1 root root 10 Jul 26 10:56 /dev/ttyCOM -> /dev/pts/0)
When experimenting with OpenHab, also had to add the permission to the specified "port" in start.sh -Dgnu.io.rxtx.SerialPorts=/dev/ttyCOM. Although, everything is perfectly functioning.
Now.
By analogy with these often change CODESYSControl.cfg to work with RS-485/USB Converter I tried to add /dev/ttyCOM in the file /etc/CODESYSControl.cfg
Thank You, Edwin.
I used to try, but nothing worked. (ttyCOM0)
After Your comment I started to study the problem deeper and found out gateway was created later than the start CoDeSys.
The problem was fixed - it works great!
Decided July 30.
Modbus RTU is bus-faillure(red) when i restart or turn on my rpi, i need to connect with Codesys development and download the app and run.
I made Create Boot App and Sourcecode download.
I tried,
IF Modbus_Slave_COM_Port.xError THEN
Modbus_Slave_COM_Port.xReset := TRUE;
but this doesn't work only change to orange from red.
Thank you.
2017-04-17
Originally created by: dosnova
Hi, I've two usb-serial devices from the same manufacturer. I've created udev rules to assing different names for both devices. Names are motor_up and motor_down. Both devices are listed in the /dev folder and both are working fine with minicom. I've added both devices to CODESYSControl.cfg:
dosnova hat geschrieben:
Hi, I've two usb-serial devices from the same manufacturer. I've created udev rules to assing different names for both devices. Names are motor_up and motor_down. Both devices are listed in the /dev folder and both are working fine with minicom. I've added both devices to CODESYSControl.cfg: [SysCom]
Linux.Devicefile=/dev/motor_up
portnum := COM.SysCom.SYS_COMPORT1;
Linux.Devicefile=/dev/motor_down
portnum := COM.SysCom.SYS_COMPORT2;
No way to make it work
I appreciate your uggestions..
You can try one by one, with codesys check. Can you show us result about this?
and then in /etc/CODESYSControl.cfg only this line will be needed:
[SysCom]
Linux.Devicefile=/dev/ttyMotor
In CODESYS you'll then access com1 for Motor0(Motor_up) and com2 is Motor1(Motor down)
2017-04-17
Thanks Edwin, now it appears to be working. I've a new question... how to add a line feed + carriage return at the end of the string I am sendig to serial device??
adding
[SysCom]
Linux.Devicefile=/dev/ttyUSB
in CODESYSControl.cfg
the runtime return STOP - program loaded exception...why?
version is 3.5.8.0
Removing the [SysCom] lines and rebooting it comes back running good (without serial communication of course)
Hello Edwin,
Peter
Hi Peter,
attached an updated Version to current 3.5.8.10
SerialComWithVisu.project [76.22 KiB] (forum.codesys.com)
Hi Edwin,
which CODESYS Version are you using?
Which Raspberry PI Package Version?
I use CODESYS V3.5 SP8 and CODESYS Control for Raspberry PI_3.5.8.0.package
Peter
Hello. I want to use internal serial port AND extrnal usb-com adapter.
I tried to add this to /etc/udev/rules.d/serial-symlinks.rules
And this to /etc/CODESYSControl.cfg
But it doesn't work(
does a
cat /dev/tty-RPI0
and cat /dev/tty-RPI1
work under Linux?
(If you connect a terminal to port and send....)
Hello. Now everything working.
I changed platform-bcm2708_usb-usb-0:1.2:1.0 to platform-20980000.usb-usb-0:1.2:1.0 for my RPI B+
sudo nano /etc/udev/rules.d/serial-symlinks.rules
sudo nano /etc/CODESYSControl.cfg
Thanks for the feedback,
helpful for others too.
Hello Edwin,
Can you Help me?
Serghei
Hi Serghei,
open older Projects should allways followed by the following procedure:
3 set current visu profile
This usually give a error free - updated project ready for using it.
Originally created by: ga-nozry
Good time, experts CDS.
I will try to describe more the problem.
Experiences spend on PI-2 mod.B
There is a controller that has only RS-232, with fixed settings ID 16, 115200,8,N,1.
There is such piece of iron - USR-TCP232-2 http://www.usriot.com/p/rs232-to-ethernet-modules/. Works perfectly in mode RTU over TCP.
Now.
however, nothing happens, not picks up data CoDeSys...
What needs to be done in the /etc/CODESYSControl.cfg [SysCom]
It seems that clearly outlined the problem.
I hope for understanding and help.
HI,
your symlinc should be:
/dev/ttyCOM0 -> /dev/pts/0
then it will work.
Thank You, Edwin.
Decided July 30.
hi,
I tried,
Thank you.
[SysCom]
I would set symbolic links in Linux
[SysCom]
$L and $R
I have a Modbus Com Error when i reboot my RPI. I share a video. Can you help me pls?
https://drive.google.com/open?id=0B92kE ... nZ2aFYxSms
Hector
guess you need to set the autorestart flag?
Thanks you Edwin,
I tried with autorestart flag too. (bad lucky )
I'm thinking in reset warm, but I don't know set autoplay after reset.
Hector
