Making a Visu Element normally invisible and visible if variable is true
2025-03-12
2025-06-06
  • peterkcontrols - 2025-03-12
    Hello
    I would like an element in my visu to be only visible when a certain Variable is true, currently it is only capable of being normally visible and then invisible if a certain variable is true. Is this possible without programming a new variable to be the opposite of my desired control variable?
    Thanks.
  • pistola - 2025-03-14
    You can use Not(Variable) in that Invisible spot.
    Example if you want it to be invisible when the bool is false then:
    Not(True) = False
    Not(False) = True
  • durallymax - 2025-06-06
    You can write any expression that evaluates to TRUE/FALSE in that property, you can also call a method from the property.
