Message in Visualization
drChiavo
2016-01-14
2016-09-12
  • drChiavo
    drChiavo - 2016-01-14
    Is it possible to prompt messages in the Visualization? If yes, how can I do that? Or which library can I use?
    What I want to do is to send a message in the Visualization in case the "start button" haven't pressed.
    Something like...
    IF xStart THEN
    xStartProcess := TRUE;
    ELSE
    XStartPorcess := FALSE;
    //PROMPT MESSAGE IN VISUALIZATION ('Please press start button to start')
  • jvondrus
    jvondrus - 2016-01-14
    I'm doing this by button element field which is hidden / shown as specific value says.
    Look for "State variables" then "invisible" and "Deactivate input". Default is TRUE = HIDDEN / DEACTIVATED, so if do you want FALSE for HIDDEN you have to put "!" after variable, like "XStartPorcess!"
  • drChiavo
    drChiavo - 2016-01-15
    I tried what you said but it didnt work. I have done a screenshot in the places where you said I should put "!".
    IMG: State.PNG
  • jvondrus
    jvondrus - 2016-01-15
    its OK, if g_Stop is FALSE you have to see your element visible and active for touch (click) event.
    g_Stop must be BOOLEAN type.
    Have you any error message in log?
  • drChiavo
    drChiavo - 2016-01-20
    Sorry, because I answered you too late. It is true that the initial status TRUE = HIDDEN but with "!" has no effect. Still TRUE := HIDDEN.
  • jvondrus
    jvondrus - 2016-01-20
    It's long time when I used it, I dot'n remember exact type. And I have not CODESYS on this computer right now.
    Maybe it required ( ).
  • Anonymous - 2016-09-12
    Originally created by: barkamharikrishna
    hi
    please used NOT before your variable .
    its works
