I have a Linux 64Bit soft PLC that is supposed to run a web visualization.
I have a valid license for the runtime - the dongle is inserted to the device and is read successfully by Codesys.
When I try to open the web visualization I see the red loading symbol that tells me that an error happened.
I can log in to the project via the CodeSys IDE and live debug - the application works fine without exceptions.
In the log under "Device" I can see these two messages:
TlsCreateContext: Creating the TLS context for namespace 'WebServer' failed.
TlsCreateContext: Failes to read certificate './PKI/cert/server.cer' in namespace: 'WebServer'
Has anyone experienced this issue before? How do I resolve it?
Of course I have rebooted the device multiple times and have even re-installed the runtime. I have also tried going back to an old backup of the project where the web visu was still working - but I get the same error...
Best Regards
hm.. strange, could us use the Security Agent to generate a selfsigned certificate?
Do you want to access the webvisu pages by http: or encrypted by https: ?
Anyway in my config it work without problem even I see this error (warning) too..!
Could you try to change the port in case there is another service running on 8080? [CmpWebServer]
WebServerPortNr=8081
for a test..?
This works without Security Agent.
Last edit: eschwellinger 2021-06-08
Hi, thank you again for your input.
I could not find any documentation on the Security Agent and the store seems to be unavailable now.
For now it would be enough for me if I could access the web visu at all, so http would be fine.
Hello everyone,
Best Regards
could you give us the whole log?
the lines above seems not to be the problem
Hi, thank you for the quick response.
This is the exported log file:
[CmpWebServer]
for a test..?
