I'm using CODESYS V3.5 SP14.
I created a WebVisu with some visualizations and downloaded it on the CODESYS Control Win V3.
When I try to access the homepage after starting the soft PLC I get the error message "cannot open document".
I already checked if the IP is correct and the name of the .htm file in the WebVisu settings.
I tryed to change the port (maybe there is another webserver running on the computer) in the CODESYSControl.cfg with
[CmpWebServer]WebServerPortNr=9090
The PLC still starts the webserver with the default port.
Does anyone have an idea what the problem here is and how I can change the port?
Thank you for your help!
Fabian
Hey,
Fabian
Should work.. which plc is it?
It's the CODESYS Control Win V3 - x64 Version 3.5.14.0.
Any Idea why the port doesn't change after editing the .cfg file?
C:\ProgramData\Codesys....
In this location the Configfile is stored.
Thank you very much!
I changed the .cfg file in the wrong path (C:\ProgramFiles\Codesys not ProgramData).
Now it's working
