summary: Various tested SparkplugB, TLS and Security scenario's --> Various tested SparkplugB, MQTT TLS Security scenario's
Description has changed:
Diff:
--- old+++ new@@ -1,6 +1,11 @@+Hi There,++This mini FAQ will to help/assist you setting up your SparkplugB MQTT TLS Channel Encryption.We have **Successfully** tested various scenario's using MQTT Client SL v1.0.2.0.
+The example will be updated shortly to accommodate these tests.-The example will be updated shortly to accommodate these tests.+* Tested against library v1.3.3.0 +* Using example v1.3.3.0 slight modifications to the example code may apply, see below for detailsTLS with client certificate on server 'test.mosquitto.org';
@@ -47,13 +52,13 @@ hCert := SysTypes.RTS_INVALID_HANDLE; //no client cert
StillGettingClientCertificate := FALSE;
- // Extra TLSContextProvider Settings+ // Additional mandatory TLSContextProvider settings sUseCaseName := 'u1',
ePurpose := SparkplugB.MQTT.NBS.Purpose.Client_Side,
sHostname := 'xxxxxx', // intentionally redacted
udiVerificationMode := 2);
- > NOTE: Additional requirements+ > NOTE: wait, yet more additional mandatory requirements! > Download Security Agent Package
> Drag the xxxxxx certificate from SecurityAgent => Devices => Qarantine... to SecurityAgent => Devices => Trusted
Diff:
