codesys.com Ingo Falk
Hardware
Usage
Now connect the outputs of the KY040 (CLK, DT, SW, +, GND) with the Raspberry Pi.
CLK --> GPIO 0
DT --> GPIO 1
SW --> GPIO 3
  • --> 5.0 VDC Power
    GND --> 0 V (Ground)
