Hi everyone,
I've a trouble with my plc
Now when I'm trying to etablish a connection with it, I've the windows: No device is responding to the scan request
But when I scan the network I'm able to see it
I'm able to ping it and I can acces to his memory by: ftp://IP_Adress
Yesterday I was able to etablish a connection with it but today (nothing has changed) It's impossible
The plc is currently running
So if someone has an idea to what to do
Many thanks in advance
Dom
Are you on the same network segment? You can get problems when you are on a switched network. For example the default broadcast addresses for network variables don't work in ours.
If you haven't tried that then try it without a switch.
Hi everyone,
Dom
which plc is this...?
maybe the bootproject is corrupt and lead to an crash on the startup of the runtime
It is a xc202 from eaton Moeller
It's the second time in one week that I've a plc which has this problem
I have a similar problem with c300 from Lenze. But the problem was an bug that i made in the code.
The problem was that we write our program on c300, and everytime it srarts has rhe same problem.
Watching log and erasing our program from cfcard solves the problem.
Responds a ping but not able to connect.
