Hey guys,
I am trying to install the CODESYS Control for Raspberry Pi MC SL and I also have the sub dongle with the license on it. I have already installed the runtime package. But when i click start these errors show up.
I have worked with this before and it all got installed and started normally. but I reinstalled the raspberry OS 64bit and ever since i have been having this same issue. I have reinstalled the OS several times.
After I pressed install a few moments later I had to choose between multicore or standard. but i could not choose multicore it was not clickable.
Error messege: [INFORMATION] Executing SSH command on pi@192.168.137.144: Start runtime system [INFORMATION] Standard output: cat: /sys/devices/virtual/bcm2708_vcio/vcio/dev: No such file or directory [INFORMATION] Standard output: mknod: missing operand after βcβ [INFORMATION] Standard output: Special files require major and minor device numbers. [INFORMATION] Standard output: Try 'mknod --help' for more information. [INFORMATION] Standard output: Error: Failed to start codesyscontrol [INFORMATION] Standard output: Error: script has to be run as root
Any help would be much appreciated.
Thank you
needs the fix which will be released with 4.4.0.0 version 24th February but
there is no 64Bit release of the Pi runtime, think you have worked with the 32Bit version before - for 64Bit you need to use: https://store.codesys.com/de/codesys-control-for-linux-arm-sl-bundle.html
64Bit version
Last edit: eschwellinger 2022-02-14
Hey thank you so much i came a bit forward. I downgraded the raspian version (Bullseye 2021.10.30) And then i keep getting this error:
Old 64bit version should work right?
Have you any idea about this maybe, thanks again for your reply.
[INFORMATION] Executing SSH command on pi@192.168.121.44: Start runtime system [INFORMATION] Standard output: Error: Failed to start codesyscontrol [INFORMATION] Standard output: Error: script has to be run as root
sorry for the reply but I got same error: [ERROR] Architecture seems to be arm64. CODESYS Control for Raspberry Pi SL is only available on the 32-bit kernel for Raspberry Pi!
sincerely after lot of try not know how to exit from this loop.
do you have any idea?
thank in advance
Last edit: mbrumini 2023-04-12
Hey guys,
Error messege:
Thank you
Last edit: ramas 2022-02-14
64Bit version
no, 64bit works
only Arm Linux Sl on 64 bit OS
Raspberry Pi MC need 32Bit OS!
Just to clarify again, so the CODESYS Control for Raspberry Pi MC SL needs a 32bit OS Right?
Thank you again
yes
thank in advance
-> use 32Bit OS or if you do on an 32Bit OS and you have executed a'sudo apt-get upgrade'
then please add in
/boot/config.txt
arm_64bit=0Thank, now it running.
