I would uninstall your 3.31 Version OSCAT lib from your library repository and install the Version from CODESYS store.
In this Version this is correct.
2017-06-16
Thanks guys for the replies.
@Edwin - perfect
Hello
I'd like to use the Oscat Basic library. The latest is 3.3.3
My target has a runtime of 3.5.10.10, and uses the Standard library 3.5.9.0
The Oscat library references 3.3.0.10 of the Standard Library. Is this a problem? I'm sure that I've read that there can only be one version.
Please see the screen shot for a clear explanation.
I have solved the problem oppening osct library, changing standard librry and recompiling.
But I it is possible that the problem could be solved in easiest form
@Edwin - perfect
