we are using the Codesys OPC server v 2.3.13.4 running on a W2K8 R2 SP2 64 bit.
Now it seems we are having problems connecting to the OPC server.
Are there know issues under W2K8 R2 that we should be aware of ?
Can you give us some hints / tips that we can check in order to get the up and running before the 1 of Jully?
Thank you
I think you should start with checking the OPCserver.log file and see what messages are given.
Then you should check where the OPCServer.ini is saved. I am not familiar with 2008 R2, but maybe you have to save the file in C:\ProgramData\CoDeSysOPC.
we have checked it with the latest V2.3 Version (CoDeSys OPC Server V2.3.13.7)
we see no specific problem. (In a special case more on the client side there where some problems)
But OPC Server seems to be ok on R2.
cu
Thank you
cu
